I think this is a common problem but I cannot seem to find the correct solution.
I have a SC2014 3d template set up where the scale is set to 1:30.
I am creating reference drawings of the water lines, electrics lines, etc in a small town. I have created custom linetype in the ACADISO.lin file by comying the GASLINE descirption, changing 'GAS' to 'W' or whatever is appropriate.
When I am in model view, the 'W' shows up fine, but, when I go to a tab to print the plan, the line is a continuous line; no 'W' is showing.
I cannot figure out what settings I have wrong...
I would like to know how to correct this and why it does this so I can avoid the problem in the future...
thanks
Thank you...that sorta helped. I did have to change one of the settings to '1'. Now, in the model tab, the 'W' is VERY large and only a few show, and when I go the printing tab and look at the view port, the 'W' does not show.
BUT, if I select a line and change the linetype scale to 0.1, it looks fine.
SO, is the solution to set the LTSCALE to 0.1 in the drawing???
Be sure the MSLTSCALE is set to 1
This is Model Space scale.
If not, the lines will display as if the scale is 1:1
