Civil 3D Forum
Linetype Mystery
32 REPLIES 32
Message 1 of 33
5063 Views, 32 Replies
Linetype Mystery
Hi Folks,
Our office has a mystery involving a linetype, specifically a treeline type. I've attached a screenshot of the issue. What you'll see there is a polyline that is displaying as dots that should be displaying as a series of half circles. The desired linetype is also in the screenshot, displaying correctly, which is coming from an xref drawing.
When working in the xref drawing, the linetype works as expected. No problems.
When working in the active drawing, the linetype appears as dots.
We have purged the problem linetype and then brought it back in with the same results.
We've also copied the linetype from the xref drawing into the current drawing. Same results.
In my research, I'm suspicious that the shapes that are used to create this linetype are somehow wacky or improperly defined in the current drawing. So, when AutoCAD attempts to display the half-circle shapes, they don't appear. I'm pretty fuzzy on how to verify this theory or correct the problem, if that is the issue.
Any insight or suggestions would be most welcome!
32 REPLIES 32
Message 21 of 33
in reply to: rl_jackson
Good thoughts and suggestions by all. Thanks for taking the time to provide your ideas. I believe I have a major clue as to the problem, but need help deciphering exactly what it means.
When the dwg is opened on a network drive, the linetype is incorrect.
When the dwg is opened on my computer, the linetype is correct.
So, why the discrepancy? How do I determine the culprit and how do I resolve it?
Message 22 of 33
AllenJessup
It sounds like there's a shape file that is on your computer that for some reason isn't found when you open form the network. Not sure about that. In the drawing you've posted I can make the lines look like dots or a continuous line by changing the linetype scale. But no Arcs.
Can you share the Linetype definition with us?
Allen
Allen Jessup
CAD Manager - Designer
Message 23 of 33
jmayo-EE
Do you have all of the 2011 service packs installed?
John Mayo
Message 24 of 33
in reply to: jmayo-EE
I believe I do, but unsure how to verify.
Message 25 of 33
in reply to: AllenJessup
Allen,
My instincts tell me that your theory is right, but I'm unsure how to move forward. Linetype definitions are attached.
Message 26 of 33
AllenJessup
OK. Daryl
From what I can figure out.... Many of the linetypes in your file were probably creates by using New-Lin.lsp form http://www.turvill.com/t2/free_stuff . Or some version of it. Note the first line in your Linetype file:
; Exported from drawing Drawing3.dwg on 2014-09-26 by ExportLinetypes
Within that lisp are the instructions:
"Any complex LineTypes using Shape Definitions for which no\n source file (*.shp) could be found will contain a reference in\n curly braces { }; the user must supply the correct shape name\n"
Your linetype:
*XTREELINE_R, Tree Line right side
A,0,-0.26,[{Shape #130},AECCLAND,S=0.13,R=180,X=0,Y=0],-0.24
The {Shape #130}  Leads me to believe that the linetype was created using that lisp to extract if from a drawing. Since it fits the pattern shown in the lisp file.
Try this modified linetype. I've altered it to pull the Tree shape from AECCLAND.SHP
A,0,-0.26,[TREE,AECCLAND,S=0.13,R=180,X=0,Y=0],-0.24
Also. The lintype in your posted drawing is *XTREELIN_R. Note the lack of an E before the underscore. I don't find that linetype in your file.
Allen
Allen Jessup
Message 27 of 33
Allen,
You nailed the issue. Your line definition works in the problem drawing. So, this raises some questions for me:
  1. When I need to create a new linetype, what's the best way to do it such that I don't have issues like this?
  2. Can this issue be resolved by somehow putting the missing shape file into the proper place? If so, that seems the past of lease effort for existing drawings. And if so, how do I do that?
Message 28 of 33
AllenJessup
  1. When creating a new linetype I usually use the lazy method of copying an existing style and modifying it to my needs. In most cases you can find one close to what you want. There are also Make Shape and Make Linetype commands in Express Tools that can make things easier.
  2. Yes. You can replace the shape file name. In many cases these are duplicates of the Aeccland.lin linetypes. Just copy and paste from that file to get good linetypes. Others use the ltypeshp.shp. There's only about 6 shapes in there. Open that file in notepad and I think you can figure it out. I didn't see any other shape files used in the one you posted. If there are. You'll have to search for the shape file being used and get the names from there.
Allen
Allen Jessup
Message 29 of 33
tcorey
Allen, as Forest's drill sargeant said to him, "You're a dad gum genius, Gump!" Nice work.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 30 of 33
AllenJessup
in reply to: tcorey
Thanks Tim. Google helped find out how the braces got in the linetypes.
Allen
Allen Jessup
Message 31 of 33
jmayo-EE
Nice catch Allen. 🙂
John Mayo
Message 32 of 33
bryan
If anyone is still having this problem in 2016+. Check your XREFOVERRIDE setting. When ours is set to 1 it has the side effect of displaying some of our linetype shapes as dots and some of our linetypes do not display at all.
Message 33 of 33
AllenJessup
in reply to: bryan
Thanks. Good one to know.
Allen Jessup
Rail Community
