Hi Folks,
Our office has a mystery involving a linetype, specifically a treeline type. I've attached a screenshot of the issue. What you'll see there is a polyline that is displaying as dots that should be displaying as a series of half circles. The desired linetype is also in the screenshot, displaying correctly, which is coming from an xref drawing.
When working in the xref drawing, the linetype works as expected. No problems.
When working in the active drawing, the linetype appears as dots.
We have purged the problem linetype and then brought it back in with the same results.
We've also copied the linetype from the xref drawing into the current drawing. Same results.
In my research, I'm suspicious that the shapes that are used to create this linetype are somehow wacky or improperly defined in the current drawing. So, when AutoCAD attempts to display the half-circle shapes, they don't appear. I'm pretty fuzzy on how to verify this theory or correct the problem, if that is the issue.
Any insight or suggestions would be most welcome!
Solved by AllenJessup. Go to Solution.
Good thoughts and suggestions by all. Thanks for taking the time to provide your ideas. I believe I have a major clue as to the problem, but need help deciphering exactly what it means.
When the dwg is opened on a network drive, the linetype is incorrect.
When the dwg is opened on my computer, the linetype is correct.
So, why the discrepancy? How do I determine the culprit and how do I resolve it?
It sounds like there's a shape file that is on your computer that for some reason isn't found when you open form the network. Not sure about that. In the drawing you've posted I can make the lines look like dots or a continuous line by changing the linetype scale. But no Arcs.
Can you share the Linetype definition with us?
Allen
Allen Jessup
CAD Manager - Designer
Allen,
My instincts tell me that your theory is right, but I'm unsure how to move forward. Linetype definitions are attached.
OK. Daryl
From what I can figure out.... Many of the linetypes in your file were probably creates by using New-Lin.lsp form http://www.turvill.com/t2/free_stuff . Or some version of it. Note the first line in your Linetype file:
; Exported from drawing Drawing3.dwg on 2014-09-26 by ExportLinetypes
Within that lisp are the instructions:
"Any complex LineTypes using Shape Definitions for which no\n source file (*.shp) could be found will contain a reference in\n curly braces { }; the user must supply the correct shape name\n"
Your linetype:
*XTREELINE_R, Tree Line right side
A,0,-0.26,[{Shape #130},AECCLAND,S=0.13,R=180,X=0,Y=0],-0.24
The {Shape #130} Leads me to believe that the linetype was created using that lisp to extract if from a drawing. Since it fits the pattern shown in the lisp file.
Try this modified linetype. I've altered it to pull the Tree shape from AECCLAND.SHP
A,0,-0.26,[TREE,AECCLAND,S=0.13,R=180,X=0,Y=0],-0.24
Also. The lintype in your posted drawing is *XTREELIN_R. Note the lack of an E before the underscore. I don't find that linetype in your file.
Allen
Allen Jessup
Allen,
You nailed the issue. Your line definition works in the problem drawing. So, this raises some questions for me:
@Anonymous wrote:
- When I need to create a new linetype, what's the best way to do it such that I don't have issues like this?
- Can this issue be resolved by somehow putting the missing shape file into the proper place? If so, that seems the past of lease effort for existing drawings. And if so, how do I do that?
Allen
Allen Jessup
Allen, as Forest's drill sargeant said to him, "You're a dad gum genius, Gump!" Nice work.
Thanks Tim. Google helped find out how the braces got in the linetypes.
Allen
Allen Jessup
If anyone is still having this problem in 2016+. Check your XREFOVERRIDE setting. When ours is set to 1 it has the side effect of displaying some of our linetype shapes as dots and some of our linetypes do not display at all.
Thanks. Good one to know.
Allen Jessup
