Civil 3D Forum
Linetype from Microstation
1 REPLY 1
bnesja
539 Views, 1 Reply
I am working with a drawing that has linetypes imported from Microstation. They are basic dashed linetypes with varied dash/gap distances; nothing fancy. My issue is that the last dash displays stretched out longer than the rest but when plotted it does not. It will actually plot the line with a gap at the end but will not display it that way. It is not as much of an issue as much as it is intriguing. I am curious as to why this would happen so I could intentionally reproduce these results.
When I use a linout lisp it produces a .lin as follows:
A,25,-75,25,75
I know that this basic text string would not create a linetype as advanced as this linetype seems to be. Any suggestions?
The attached IMAGE is a screenshot of the line in question (circled in red)
The attached PDF is how it actually plots
1 REPLY 1
rkmcswain
in reply to: bnesja
Since some MS linetypes can't be represented by AutoCAD, they had to come up with a different way of doing it other than the traditional linetype definition. To the best of my knowledge they do it with anonymous blocks, data stored in dictionaries, etc. - which one day became a problem and let to the DGN linetype bloat problem, which has since been fixed.
More info: http://bit.ly/11QUiOz
Rail Community
