Civil 3D Forum
Lines to Northing Easting elevations
4 REPLIES 4
ADRooney
851 Views, 4 Replies
How to convert these text to polylines. And extract points.
4 REPLIES 4
Alfred.NESWADBA
in reply to: ADRooney
>> And extract points.
On one side I assume it's a crosspost to >>>that message<<<
Also your questions are to short to know what you really mean. Tell us more about what you like to do as I don't think you really want to convert the text to polylines (resulting in the outlines of each character are then drawn as polyline, which could be done by command _TXTEXP from express tools).
What do you mean by "extract points", what points should be "extracted" and what result do you want to achieve.
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
BrianHailey
If you only have a few pieces of text you want lines drawn through, just snap to them (either NODE or INSERT snap).
As for "extracting points", I would guess a data extraction would work.
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
ADRooney
Thank you for the reply.
If you see the text properties they have X Y values. So do they resemble the northing easting positions.
So my question is how to insert a point at those text and create a point group ?
Alfred.NESWADBA
run command _DATAEXTRACTION, the result of that is an ASCII-file, then use the C3D-command _AECCCREATEPOINTS (7th icon in the tool) to import points from that ASCII-file.
- alf
Alfred NESWADBA
Rail Community
