The above sums it all up. Note the properties are NOT GREY they are what they are supposed to be.
The file was created in version 2012 by another designer now it is being completed in 2013 by myself.
I can do a quick fix by creating a wblock of the problem lines and text etc to enable a print out without the GREYING
problem but once the drawing is closed and opened once again the drawing has GREYED whatever is in model space again. (note that xrefed lines etc are fine)
Please help me fix this.
Regards
Carla Featherstone
Ps I have attached the problem file with all the xrefs and jaz unattached/taken off etc
Solved by bobwesterman. Go to Solution.
dumb question but I'll ask it.
I dont have cad handy but in the plot settings is "display plot styles" checked?
Joe Bouza
I don't know what causes this, or how to correct it, but the 2d Wireframe Visual Style is messed up. Chnage to any other visual style and the linework shows correctly, change it back the the 2d wireframe and it gets hosed. You can work around it by inserting the drawing into a new drawing, then use Design Center to bring in the layouts.
Thanks Jeff I'm pretty sure that inserting into another drawing doesn't work too. That was interesting about the wireframe. Not sure what to do still Thanks for your time Carla
Edited by
Discussion_Admin
So you inserted a wblock into another drawing? Is that right? I will give that a go now to check it Talk soon
Edited by
Discussion_Admin
I just read this post about an hour ago:
Sound about the same to me.
