Valued Contributor
asloat
Message 1 of 6 (121 Views)
Lines not printing behind screen
121 Views, 5 Replies
01-17-2013 05:44 AM
Has anyone seen this before and possibly know a solution?
I have a drawing with a screen and behind it is an xref drawing. When I print it to our KIP plotter the lines and other items behind the screen do not plot.
Here is how it is setup and what I have tried
The Xref itself is on its own layer and all the layers of the xref are set to a color that has thickness of .0138 and a 35% screen.
The hatch resides in the active drawing and is set to a color that is also .0138 thick but at a 20% screen.
The hatch is a DOT hatch at scale 1, but I have also tried it as a solid hatch
Lines merge is on and needs to be on.
I have made sure that the hatch is sent to the back and that there is no overlapping of data from other sources liek a second hatch or the same data in another xref etc.
I also tried setting the xref layers to another color that is .0256 thick with a 35% screen, but the results where the same. If i change the xref layers to a .0138 thick color with 100% screen, they do print over the hatch then.
I have also found that if I use the same plotter but with a post script drive, it does work as setup, though that creates other issues that are not ideal.
TRogers
Message 2 of 6 (115 Views)
Re: Lines not printing behind screen
01-17-2013 06:24 AM in reply to: asloat
In the plotter settings, do you have it set to Lines Overwrite, or Lines Merge?
If the issue was resolved by this method, please click on "Accept As Solution"
*Civil 3DJ*
Todd Rogers
Visit my blog here.
Valued Contributor
asloat
Message 3 of 6 (113 Views)
01-17-2013 06:33 AM in reply to: TRogers
We use "lines merge" for a variety of reasons, though I need to toggle it on each time I plot as we are not currently using PC3s.
TRogers
Message 4 of 6 (112 Views)
01-17-2013 06:34 AM in reply to: asloat
You might want to try Lines Overwrite.  See if that works...
*Civil 3DJ*
Todd Rogers
Visit my blog here.
Valued Contributor
asloat
Message 5 of 6 (111 Views)
01-17-2013 06:36 AM in reply to: TRogers
Lines overwrite is not an option for my company.
Member
g.diazfonseca
Message 6 of 6 (102 Views)
01-17-2013 07:41 AM in reply to: asloat
There is not much different between 20% and 35% screen. Try using a 40% or 50% instead, also if the hatch is in his on layer assign a transparency value to it (that may help, but turn on transparency on the plot settings)
