Civil 3D Forum
Lines not printing behind screen
5 REPLIES 5
asloat
300 Views, 5 Replies
Has anyone seen this before and possibly know a solution?
I have a drawing with a screen and behind it is an xref drawing. When I print it to our KIP plotter the lines and other items behind the screen do not plot.
Here is how it is setup and what I have tried
The Xref itself is on its own layer and all the layers of the xref are set to a color that has thickness of .0138 and a 35% screen.
The hatch resides in the active drawing and is set to a color that is also .0138 thick but at a 20% screen.
The hatch is a DOT hatch at scale 1, but I have also tried it as a solid hatch
Lines merge is on and needs to be on.
I have made sure that the hatch is sent to the back and that there is no overlapping of data from other sources liek a second hatch or the same data in another xref etc.
I also tried setting the xref layers to another color that is .0256 thick with a 35% screen, but the results where the same. If i change the xref layers to a .0138 thick color with 100% screen, they do print over the hatch then.
I have also found that if I use the same plotter but with a post script drive, it does work as setup, though that creates other issues that are not ideal.
5 REPLIES 5
ToddRogers-WPM
in reply to: asloat
In the plotter settings, do you have it set to Lines Overwrite, or Lines Merge?
Todd Rogers
asloat
in reply to: ToddRogers-WPM
We use "lines merge" for a variety of reasons, though I need to toggle it on each time I plot as we are not currently using PC3s.
ToddRogers-WPM
in reply to: asloat
You might want to try Lines Overwrite.  See if that works...
Todd Rogers
asloat
Lines overwrite is not an option for my company.
in reply to: asloat
There is not much different between 20% and 35% screen. Try using a 40% or 50% instead, also if the hatch is in his on layer assign a transparency value to it (that may help, but turn on transparency on the plot settings)
Rail Community
