Distinguished Contributor
lsimms1
Message 1 of 9 (1,694 Views)
line weight in paper space
1694 Views, 8 Replies
04-28-2011 12:37 PM
We have a few drawings where the lineweights between paper space and model space vary on plots.
ie a line on Layer 1 in model space plots heavier/darker than a line on Layer 1 in paper space.
Why is this happening?
Sinc
Message 2 of 9 (1,687 Views)
Re: line weight in paper space
04-28-2011 12:51 PM in reply to: lsimms1
I can think of two possible causes:
  1. You have a layer override in your paperspace viewport.
  2. You have different Plot Style tables assigned.
Sinc
lsimms1
Message 3 of 9 (1,680 Views)
04-28-2011 01:14 PM in reply to: Sinc
No overrides.
In the layer properties, everything matches between paper and vp settings.  Unless there is another setting somewhere I have not noticed?  (please let the answer be this simple)
This has happened in the past on acad and ldd programs so its not limited to C3d.  Not all drawings do this, but some.  Makes me think it is a drawing setting somewhere.
Product Support
AlmasSuljevic
Message 4 of 9 (1,653 Views)
04-29-2011 06:09 AM in reply to: lsimms1
HI Isimms,
What happens if you change plot scale. Does the lineweight changes? If it does, then check your Plot dialog and the "scale lieweight" toggle setting.
Almas Suljevic
Product Support Specialist
Autodesk Global Subscription and Support
Please click on "Accept as Solution" if post helped you resolve the issue.
lsimms1
Message 5 of 9 (1,617 Views)
05-02-2011 05:21 AM in reply to: lsimms1
Not that either.
Keep the guesses coming.  Sooner or later there will be the right one.
Active Member
sslate
Message 6 of 9 (1,106 Views)
10-02-2012 11:50 AM in reply to: lsimms1
Did you ever figure out what was causing your issue?  I have the same thing going on in my drawing.
lsimms1
Message 7 of 9 (1,077 Views)
10-03-2012 05:29 AM in reply to: sslate
Sorry, no answer for you.
It may be a plotter setting issue. (?)
Lately I have been plotting to pdf, not a plt file or direct plot.  Have not had it happen since.
New Member
emregeckin
Message 8 of 9 (668 Views)
07-17-2013 11:36 PM in reply to: lsimms1
set psltscale to zero. (PaperSpaceLineThicknessSCALE)
lsimms1
Message 9 of 9 (656 Views)
07-18-2013 04:08 AM in reply to: emregeckin
You can try this, but it didn't help for me. (at the time it was c3d 2008, maybe in later versions this is the answer)
I would be very interested in finding the answer even though I have not had that happen recently.
