Umm, yep.
John Mayo, PE
Project Engineer
Conklin Associates
Ramsey, NJ
Civil 3D 2008, LDT 2008, Raster Design 2008
P-IV at 3.5 GHz
2 GB Ram
Nvidea Quadro FX w/ 128 MB Ram
"TomD" wrote in message
news:5857725@discussion.autodesk.com...
..............and if you're changing LT scale for individual objects, for
pete's sake, are you sure you really want to do that?
MSLTSCALE is NOT a per-object setting. A bit of reading up on LTSCALE and
related settings may well be in order.
"John Mayo" wrote in message
news:5857516@discussion.autodesk.com...
Set it to zero if you do not want the lines to scale set it to 1 if you want
them to scale as per the annotation scale.
John Mayo, PE
wrote in message news:5857443@discussion.autodesk.com...
Thank you v m. Mr Mayo
Command MSLTSCALE works but may I ask how the scale works? cause when I do
this, the dimension changes for sll lines I apply it to.
2008 Civil 3D
