Civil 3D Forum
Line Labels to span segments
3 REPLIES 3
normans
380 Views, 3 Replies
In trying to learn more about label styles, the C3D Help instructs one to:
2.  On the Layout tab of the Label Style Composer, select or create the label component that you want to span multiple          segments.
3.  In the Properties list, under General, change the Span Outside Segments property to True.Specify this setting for each component that you want to span multiple segments.
There is no "Span Outside Segments" to set to True in my Label Style Composer. Anybody run into this? The only T/F option under General is for visibility.
Civil 3D 2015 SP 2, 64 bit
Dell Precision T5600, 16 GB
Win 7 Professional 64 bit
Intel Xeon @ 2.0 GHz
NVIDIA Quadro 4000
Tags (2)
3 REPLIES 3
Jeff_M
in reply to: normans
This option is only available under Parcel Segement Label Styles:
normans
I answered my own question - I should be in Parcel-Line Styles not General-Line Styles.
NVIDIA Quadro 4000
normans
in reply to: Jeff_M
Thanks much!
NVIDIA Quadro 4000
Rail Community
