I feel foolish here - but I have a new project drawing and I need to add bearings and distances to my property lines. All of my label styles are set up. When I click on a line nothing shows up in the drawing. I've been trying to label the same line for several hours now and have given up looking for a reason the labels are not showing up. All the layers are on in the drawing as well. This has never happened to me before...
Current Version C3D 2011
Win 7 64
Been using AutoCad since 1985.
For some reason the default layer for line labels is layer 0. Make sure you have layer 0 thawed. I still haven't figured out how to make it put them on a text layer. I have to create a selection set and do it by hand.
Probably your quickest fix is to either post the drawing or a portion of the drawing if it has the same problem.
Bill
I just changed the visual style under MISC in Properties to Hidden and the line tables showed up along with the tag labels. I made the tables thinking that the labels were somehow being inserted as tags. OK, so now I have found this new toggle, so now I need to figure out why my labels are being inserted as tags...
OK - I figured out where the switch is to set the style from Tag to Label. I would like to find out what the Visual Style has to do with my labels though if anyone knows. The only reason this would be a factor in one of my drawings is because I have a TIN in there.
