I have had multiple drawings where after inserting basic line labels for bearing and distance of a line, the line label will disppear. The original Line Lable Style is set for the Display Mode to be Label. After the labels dissappear the Line Label Style is changed Tag Mode. I know the setting isn't getting changed by a person, but it is changing automatically after labeling, closing and then reopening the drawing. I am wondering why it continues to change. Although the fix is simple and I know what to look for now, it is still frustrating that it keeps changing.
Thanks in advance for any info as to why this is happening.
What version of Civil 3D are you running? Do you know if these troubled drawings were created by the same template? The reason I’m asking is that it appears there may be some form of corruption in these drawings. See if you can use WBLOCK and then insert this drawing in another clean template. That may fix the issue.
I am using 2013.
That is more than likely the issue, the drawings were originally created in LDD 2008 and then opened in C3D and revisions were made using C3D. Next time the problem arises, I will try to block everything out into a new drawing.
Thanks.
