Civil 3D Forum
line labeling
7 REPLIES 7
Message 1 of 8
jsauler
290 Views, 7 Replies
line labeling
Good day folks, It has been a while since I have been on here but I have something that has been stumping me and I even asked @autodeskhelp on Twitter and they couldn't find anything. Here is what I want to do.
I want to label a breakline, BUT, I want to reference the info, ie., bearing & distance of the original or shall I say hidden line that the breakline is representing. I want to do this so I don't have to edit the label. I just want to remove that step and take the human error out of the equation. Or shall I say "some" of the human error.
What say you?
Tags (1)
7 REPLIES 7
Message 2 of 8
BrianHailey
in reply to: jsauler
I'm not sure I understand. Civil 3D doesn't have "breaklines". It has featurelines, polylines, survey figures, parcel segments, 3D polylines, etc. that a surface can then use as a breakline but you can't label a breakline.
All of the mentioned objects can be labeld in Civil 3D and, at the same time, be used as a breakline in a surface.
Perhaps we just have a terminolgy issue and what you are referring to as a breakline is something other then what I think of as a breakline.
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
Message 3 of 8
jsauler
in reply to: BrianHailey
Sorry about not being clear on this. I was not referring to a surface breakline. I was referring to a break-line. Here is an example of what I want to do.
Message 4 of 8
randcdavidson
Annotate the line that you need information from and then drag the label over the the breakline. Make sure that the style of the label has the leader turned off.
Message 5 of 8
saross622
When I have labeled these lines in the past, the Label is in Model Space on the line drawn to its full length. Then in Paper Space I either draw line work of the tie-in point or create a small vport of the tie-in. Then draw the break symbol in Paper Space between the 2 vports, sometimes when space is a premium I add a wipeout under the symbol to show the proper symbol.
Scott
Message 6 of 8
caddie99
2 viewports with nonplot borders and the squiggle mark (in paper space) is the method I use
also
you could draw the full line in a non plot color, label it and send it behind your break line
Message 7 of 8
jsauler
in reply to: randcdavidson
But what do you do if the label is not on a horizontal plane? The dragged label always rotates to 0°. How do you keep it the same rotation as the original label?
Message 8 of 8
saross622
When the label is on the line you should see a double arrow grip when you click on the text, this should let you move the text along the line and not have the justification change.
But if you need it be dragged off the line, under the "Dragged State" tab you can change the Display setting to As Composed. Now the text should maintain the same orientation as set in the "Layout" tab.
Rail Community
