Good day folks, It has been a while since I have been on here but I have something that has been stumping me and I even asked @autodeskhelp on Twitter and they couldn't find anything. Here is what I want to do.
I want to label a breakline, BUT, I want to reference the info, ie., bearing & distance of the original or shall I say hidden line that the breakline is representing. I want to do this so I don't have to edit the label. I just want to remove that step and take the human error out of the equation. Or shall I say "some" of the human error.
What say you?
I'm not sure I understand. Civil 3D doesn't have "breaklines". It has featurelines, polylines, survey figures, parcel segments, 3D polylines, etc. that a surface can then use as a breakline but you can't label a breakline.
All of the mentioned objects can be labeld in Civil 3D and, at the same time, be used as a breakline in a surface.
Perhaps we just have a terminolgy issue and what you are referring to as a breakline is something other then what I think of as a breakline.
Sorry about not being clear on this. I was not referring to a surface breakline. I was referring to a break-line. Here is an example of what I want to do.
Annotate the line that you need information from and then drag the label over the the breakline. Make sure that the style of the label has the leader turned off.
2 viewports with nonplot borders and the squiggle mark (in paper space) is the method I use
also
you could draw the full line in a non plot color, label it and send it behind your break line
But what do you do if the label is not on a horizontal plane? The dragged label always rotates to 0°. How do you keep it the same rotation as the original label?
