Civil 3D Forum
Line labeling (bearing, dist, crow's feet) question
2 REPLIES 2
Rubixcube10
1853 Views, 2 Replies
I'm trying to annotate my lines but i'm having problems fixing what pops up. I can't get the crow's feet into the drawing, my bearings seconds goes into 2 decimal places, my height won't change & my distance is 3 decimal places. I used the add line & curve label to annotate my lines. I've tried to go in and edit the text and to change the decimal place but nothing changes. I've gone into the label style composer - (span) bearing & distance with crows feet, changed the text height but that didn't work. Can't find where to change the decimal place in here and baffled why the crows feet won't appear. All help is appreciated, thanks. Unfortunately, I cannot add any attachments at the moment. I tried 2 different ones and nothing saves.
Rob
HP Compaq 8100 Elite
Win 7 Pro SP1 - 64Bit
8GB RAM
i7 860 @ 2.80 GHZ
AutoCad Civil 3d 2012 SP1
2 REPLIES 2
rl_jackson
in reply to: Rubixcube10
Rick Jackson
Survey CAD Technician VI
rl_jackson
in reply to: rl_jackson
With regards to the text make sure that you selecting the correct component name, if you change the height of the Table Tag, you just changing that, pull down the component name on the layout tab to the B&D and change the height.
WIth regards to the crows foot - check the visibility of the component.
Rick Jackson
Rail Community
