Is it true that a line Label (a line tag, for instance) will not display unless the entity that it is attached to is displayed (not frozen or off)?
I know that you cannot create a tag by picking pts, you have to pick a line. But I have many tags (containing bearing and distance) that I need to display to different pts along a line, all measured from the same pt.
I thought I had this solved by drawing the necessay lines (all overlapping) and freezing their layer, but that apparently freezes the label as well.
I could make that layer not plottable, but I would still have to look at that layer.
Any better ideas on how to have the labels display but not the lines, or a better method for what I want to accomplish?
Steve (using C3d 2010, no SP)
Thanks Jeff, good idea, or I may just make some fake tags(i.e. text saying L152) and only thaw the real Tag when it's "table time".
Steve
