I have created six different line labels to show different information in parts of a drawing. They are all on layer BNDY-TXT layer which was used when labeling. They all indicate the appropriate the appropriate Component Name is VISIBLE and display in model space. However only some of the labels display in paper space and others don't, even though they are all on the same layer Is there a setting in need to change.
Are the objects being labled thawed? I recentley discovered if you label a line, then freeze the line the label will disappear, even if it is on another unfrozen layer.
If this is the case set the layer to no-plot instead of using vpfreeze.
John Mayo
Yes, try moving the line off of the defpoints layer. That layer behaves funny, and I've heard it acts as though it is frozen even when it isn't. I've always avoided using the defpionts layer because of issues like these.
@Anonymous wrote:
the line (on layer Defpoints, label on BNDY-TXT) is on in the viewport and still does not show.
Since the line is on Defpoints, also check layer '0'. Best practice is to not use Defpoints, but instead use a layer set to not plot.
~ Mary
Thanks for your assistance I believe the problem is solved by changing the label association line to a different layer and then freezing in plot configuration.
