Civil 3D Forum
Line Elevations
6 REPLIES 6
hwyenginr
322 Views, 6 Replies
Line Elevations
When I draw a line segment I am getting zero elevations even though I am snapping to nodes with elevations. Why is this
6 REPLIES 6
wfberry
in reply to: hwyenginr
osnapz = 1
or
Nodes are NOT set to elevations (C3D Points can have elevations with node at "0" elevation.)
hwyenginr
When I click on the nodes the properties says they have elevations but the lines don not snap to the elevation. Reset osnapz to "1" still not getting elevations.
Thanks for the reply
need to check the style of the point node.   it is probably set to flatten elevations to zero.
AllenJessup
Try doing an ID on the node to verify the elevation.
Allen
Allen Jessup
CAD Manager - Designer
hwyenginr
The point style was set to flatten
Thanks much
You're very welcome.  Please mark it as the solution to your question so that others can find a solution to the same problem quickly.
Rail Community
