Mark Green
Working on Civil 3D in Canada
I am not sure if this is the answer you are looking for, but it is useful information.
When you create a line the elevations of the end points can vary from point to point allowing the line to have a slope. If you are drawing a Polyline the entire line is forced to be at the same elevation, it does not have to be zero, but all of the vertex must have the same elevation. If you draw a 3d polyline or a feature line then each vertex can have seperate elevations.
OSNAPZ Variable can have an effect on the information above.
If set to 0 the each click takes into account the z value of the click.
If set to 1 the autocad ignores the z value and assumes 0.
I hope you find this helpful.
If you draw a polyline a select the first known cogo point the polyline will take the elevation from the point and all clicks after will hold the same elevation. then if desired you can explode the PL and it will become multiple lines all at the same elevation.
Mark Green
Try typing in the command "elevation" to see if it has been changed to anything but zero. Then obviously put in zero.
Hope this helps,
