AutoCAD Civil 3D General Discussion
0 Kudos
Post 1 of 17
Line Bearing Label Expressions
756 Views, 16 Replies
11-15-2012 02:07 PM
I am trying to get my bearing label short name spaced to read with a "." after the N & E. Example: N. 00 00 00 E. Does anyone have a clue how to achieve this?
Thank you,
Rich
*Expert Elite*
267 Kudos
Post 2 of 17
Re: Line Bearing Label Expressions
11-16-2012 05:58 AM in reply to: richkerlin6830
I would have expected something like that to be in the Abbreviations tab under Drawing Settings, yet a quick look there didn't reveal it.  Sorry.
Credit where credit is due! Give kudos or accept as solution whenever you can.
*Expert Elite*
485 Kudos
Post 3 of 17
11-16-2012 06:41 AM in reply to: richkerlin6830
I haven't done this but what I think you'd have to do is to develop expressions that would separate the bearing in to it's first quadrant component, it's angle component and it's second quadrant component. They you'd have to edit the Label Style component contents to read something like:
<[First Quadrant component]>. <[Angle]> <[Second Quadrant component]>.
It looks like this would take some work to get it right.
Allen
*Expert Elite*
267 Kudos
Post 4 of 17
11-16-2012 06:54 AM in reply to: AllenJessup
So Allen there is seriously no way to edit the abbreviations for North, South, East & West?  I thought all this stuff was accessable.  What if I wanted them to say A, B, C, D, or 1, 2, 3, 4?  Or Q, X, Z, P?  (Because I'm crazy and/or work for some foreign spy agency) I should be able to, right?
*Expert Elite*
485 Kudos
Post 5 of 17
11-16-2012 07:14 AM in reply to: troma
If you WERE crazy enough, then you'd probably be crazy enough to figure out how to do it with expressions. I've seen similar things done but I can't find an example at the moment.
Allen
*Expert Elite*
267 Kudos
Post 6 of 17
11-16-2012 07:16 AM in reply to: richkerlin6830
You mean something like this?
http://screencast.com/t/jtgJXupOq
A bit much to explain here. This weekend I'll try to write up a blog post on how to achieve this. Basically, just add a text component that is a period and locate it correctly.
Brian Hailey
CAD-1.com
My Blog
*Expert Elite*
485 Kudos
Post 7 of 17
11-16-2012 07:21 AM in reply to: BrianHailey
Very interesting. I'm looking forward to reading about it. I'm thinking that the "locating it correctly" is the key.
Allen
0 Kudos
Post 8 of 17
11-16-2012 07:28 AM in reply to: richkerlin6830
Thanks Brian. That is exactly what I'm looking for. Look forward to reading your blog.
Rich
*Expert Elite*
485 Kudos
Post 9 of 17
11-16-2012 07:41 AM in reply to: richkerlin6830
Brian gave me a clue. I created a text component having just a period in it, anchored it to the Bearing and messed around with the offsets until it fell in the right place. I suppose to get the second one you could create another text component or figure out how many spaces to put between the two periods.
Brian may have an even better way.
Allen
*Expert Elite*
267 Kudos
Post 10 of 17
11-16-2012 07:44 AM in reply to: BrianHailey
You can do everything with expressions, apart from set the text height for a reference text component, apparantly.
http://forums.autodesk.com/t5/AutoCAD-Civil-3D/Alignment-Label-with-Reference-Text-amp-Expressions/m...  )
I still think you should be able to simply change the required abbreviation in the abbreviations tab.  Can anyone think of a good reason for not having it in there?
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
