I am trying to get my bearing label short name spaced to read with a "." after the N & E. Example: N. 00 00 00 E. Does anyone have a clue how to achieve this?
Thank you,
Rich
I would have expected something like that to be in the Abbreviations tab under Drawing Settings, yet a quick look there didn't reveal it. Sorry.
Mark Green
Working on Civil 3D in Canada
I haven't done this but what I think you'd have to do is to develop expressions that would separate the bearing in to it's first quadrant component, it's angle component and it's second quadrant component. They you'd have to edit the Label Style component contents to read something like:
<[First Quadrant component]>. <[Angle]> <[Second Quadrant component]>.
It looks like this would take some work to get it right.
Allen
Allen Jessup
CAD Manager - Designer
So Allen there is seriously no way to edit the abbreviations for North, South, East & West? I thought all this stuff was accessable. What if I wanted them to say A, B, C, D, or 1, 2, 3, 4? Or Q, X, Z, P? (Because I'm crazy and/or work for some foreign spy agency) I should be able to, right?
Mark Green
If you WERE crazy enough, then you'd probably be crazy enough to figure out how to do it with expressions. I've seen similar things done but I can't find an example at the moment.
Allen
Allen Jessup
You mean something like this?
http://screencast.com/t/jtgJXupOq
A bit much to explain here. This weekend I'll try to write up a blog post on how to achieve this. Basically, just add a text component that is a period and locate it correctly.
Very interesting. I'm looking forward to reading about it. I'm thinking that the "locating it correctly" is the key.
Allen
Allen Jessup
Brian gave me a clue. I created a text component having just a period in it, anchored it to the Bearing and messed around with the offsets until it fell in the right place. I suppose to get the second one you could create another text component or figure out how many spaces to put between the two periods.
Brian may have an even better way.
Allen
Allen Jessup
You can do everything with expressions, apart from set the text height for a reference text component, apparantly.
I still think you should be able to simply change the required abbreviation in the abbreviations tab. Can anyone think of a good reason for not having it in there?
Mark Green
If a space is the same width as a letter (may depend on the font you're using) then it should be simple.
Text component: " ." that is a space, then dot.
Anchor bottom left of this component to the bottom left of the main label component.
Then add another dot, and play with the number of spaces between them.
But if N and S are different widths you're in trouble. W is a difficult letter, generally wider than others, so you may be better off with a second dot componant anchored to the bottom right of the main label, rather than having both dots in one component.
Mark Green
Allen
I tried what you suggested and it works great when you line is drawn left to right but when you rotate the line right to left the period does not move with the first letter
Oh well. We'll have to wait for Brian then.
Allen
Allen Jessup
@AllenJessup wrote:Brian gave me a clue. I created a text component having just a period in it, anchored it to the Bearing and messed around with the offsets until it fell in the right place. I suppose to get the second one you could create another text component or figure out how many spaces to put between the two periods.
Allen
Basically the same, I just created a letter that I attached middle left to middle left and then attached the period middle right to middle left. Then set the visibility of the letter to false.
As for the period at the end, just add it to the bearing label. http://screencast.com/t/rq4E6RjLznbF
On the general tab, set the "Flip Anchors with Text" option to True.
Can't get text to appear
Oh! NOW it works
Allen Jessup
Duh!!! That's what happens when trying to do styles while plotting a 66 acre deed. Only a 52' missclosure. So all is well.
I feel honored. For some reason IT isn't blocking access to screencast.com today
Allen
Allen Jessup
