hello,
can someone help me display the line angle in gons in properties or pop up window?
i changed every angle unit i foubd inthe settings dialogue an i still gett degrees.
thanks!
Solved by Jay_B. Go to Solution.
For the overall Drawing Setting for Angles set it here:
Settings Tab of Toolspace>Rt. Click on Drawing name>Drawinng Settings>Ambient Settings Tab>Angle>Grad
To get it to display as Grads in the Properties Palette etc. enter UNITS @ command line and set "Angle" to Grads.
Knowing that 90 degrees = 100 gons, I would think that having an Excel spreadsheet handy for quick conversions would be the way. If you were to use an alignment there are ways to show an intersection angle and could perhaps use an expression for a label.
Bill
