In previous versions of ACAD, there was a very helpful tool called "Line and Arc Info". I am currently running C3D and cannot locate this helpful tool. Did Autodesk do away with it? Any information will be greatly appreciated!
Analyze tab, Inquiry palette at the right hand end. There is a whole list of tools that used to be on the Inquiry menu. Don't forget you can also use "Where is my Command" to help locate commands it is in the help menu.
