Civil 3D Forum
lidar point cloud (LAS) files to Civil 3D
12 REPLIES 12
Message 1 of 13
5825 Views, 12 Replies
Does anyone know of a method to import lidar point cloud (.las) files into
Civil 3D surfaces? If C3D itself won't do it (and it doesn't seem to), is
there some middleman software that can convert the LAS files to NEZ (text)
points or contours which can then be used to create a C3D surface?
Ralph Sanchez
www.texupport.net
12 REPLIES 12
Message 2 of 13
http://home.iitk.ac.in/~blohani/LASUtility/LASUtility.html
Do a web search for Convert LAS and you'll have more options.
C3D doesn't handle LAS directly.
"Ralph Sanchez" wrote in message
news:6083465@discussion.autodesk.com...
Ralph Sanchez
www.texupport.net
Message 3 of 13
Hi Ralph,
We will be releasing a new version of TopoGX shortly that loads LAS
files. From there you can do a multitude of things.
- You could simply save it out to CSV or as you call it ENZ.
- Contour it and save them out...but thats not recommended as you will
loose surface accuracy.
- You could also save out the automatically generated surface as a set
of DXF 3D Faces or even a set of polyface meshes.
If its only one small file, you could try posting it here and Ill take a
look at converting it to CSV. Dont forget to zip it though.
Hope this helps,
Dave
Message 4 of 13
> into Civil 3D surfaces? If C3D itself won't do it (and it doesn't
> seem to), is there some middleman software that can convert the LAS
> files to NEZ (text) points or contours which can then be used to
The MapWorks Mass Points processor will let you select hundreds of
binary LAS files, then limit the area to a closed object and
intelligently throw out some unnecessary points. If a LAS tile falls
completely outside the boundary its ignored in a fraction of a second.
Why not get a 14day full working demo and get the job done on us. We're
hoping you'll get hooked.
Email me at dotson [at] dotsoft [dot] com if you have any questions.
Terry
Never start any job without the right tools!
AutoCAD Add-on Tools at http://www.dotsoft.com
Message 5 of 13
Dave,
I appreciate the offer, but I need to convert about five LAS files and they
average about 200MB each.
Ralph Sanchez
www.texupport.net
"Dave" wrote in message
news:6083503@discussion.autodesk.com...
Hi Ralph,
Hope this helps,
Dave
Message 6 of 13
Terry,
This sounds exactly like what I need. I sent you an email to request a
trial version.
Ralph Sanchez
www.texupport.net
"Terry W. Dotson" wrote in message
news:6083519@discussion.autodesk.com...
Terry
Message 7 of 13
mike.barkasi
[http://www.youtube.com/watch?v=vSUFF5NmmxI]
I cant believe noone suggested PowerCivil. We import Lidar LAS data. The same tools can also be found in Inroads and GEOPAK.
Mike Barkasi
Bentley Civil
Professional Services
Message 8 of 13
mike.barkasi
14 day free trial... cmon Terry even PowerCivil software has a 30 day grace period built in.
Message 9 of 13
Strive for distortion don't you. PowerCivil (a competitive product) is
at least twenty times larger (because of *duplicate* functionality) and
probably 20x more *expensive* than our AUTOCAD ADD-ON. So you would
need to offer a 280 day trial to compare.
Terry
Message 10 of 13
ACADuser
Could you imagine walking into a high performance car parts shop and asking for something that would boost the hp on your vehicle. The tech say's "There are many options....." and the guy behind you say's "I can't believe no one suggested a different vehicle".
ACADuser
Civil 3D 2018, Raster Design 2018
Windows 7 Enterprise
Dell Precision 5810 Workstation
Intel Xeon E5-1630 v3 @ 3.70GHz
32GB RAM, NVIDIA Quadro K2200 4 GB GDDR5
DUAL 27" Dell UltraSharp U2713HM
Message 11 of 13
mike.barkasi
I was being sarcastic for Terrys sake. 🙂
Good analogy though. Though High performance is a bit off when you look at all the negative postings. Besides alot of people have more than one car to serve multiple purposes. V8i is all about interoperable so designers can use the right tool for the job.
Mike Barkasi
Bentley Civil
Message 12 of 13
> negative postings.
Of course you wouldn't find any negative posts on the Bentley NGs.
Terry
Message 13 of 13
ACADuser
Those that frequent the DG's are mostly looking for solutions to problems or ways to enhance their work process. I'll admit that I sometimes express my frustrations here in the DG's when requesting help with a problem. When others express there frustrations, I don't see it as negative since I can understand where they are coming from. The reason I use this valuable resource is there are others that will see things differently and give you a completely different angle to approach the problem. This helps prevent wasted time trying to fix every little problem on my own while working through a project. Not to mention, it also keeps me positive. 🙂
ACADuser
Rail Community
