<rrawls@quad3.com> wrote inI
message
href="news:6076078@discussion.autodesk.com">news:6076078@discussion.autodesk.com...
need to use LIDAR data to create surfaces. I've followed the routine
previously posted but end up with an error. My procedure is as follows: 1. Map
Import a contour shp file 2. Create object data 3. The contour lines display
but all with 0 elevation and correct elevation is displayed under object data
4. Define Query 5. Query type: Location ALL 6. Query mode: Draw 7. Press Alter
Properties button 8. Select ELEVATION 9. Press Expression button 10. Select
ELEVATION 11. Press Add button 12. Press OK 13. Press Execute Query button
This is where a message "Query source is not available or empty" appears Any
help would be appreciated. All associated data and files with the shape file
are also located in the same folder as the .shp file.
<rrawls@quad3.com> wrote inThanks
message
href="news:6076210@discussion.autodesk.com">news:6076210@discussion.autodesk.com...
for the input. I tried it both ways, directly in the contour dwg. and also
with the contour dwg. attached. Same error.
