colt wrote:
> I need to create cross sections for 32km pipeline ROW (approx.20m
> left and right of the centerline) and I want to use 1.0m LIDAR data
> as a point file.The problem is the amount of data I will end up with
> and the ability of Civil 3D/LDD to manage it!I have used LIDAR data
> in the past, for grading and volume calculation,but I had to resample
> it to 5m and loose the benefit of high resolution data.Any
> suggestion or experience working with LIDAR in Civil3D or LDD data is
> highly appreciated.
Colt,
Whether you do this in Land Desktop or Civil 3D, you will NOT want to
import the point file that you create. You can assign an external
point file to your surface definition, which will keep you from having
to import the points. I'm betting that it'll still be slow, but it
will definitely work better than inserting the points.
Jason Hickey
Civil 3D 2007
Dell Inspiron 9100
3.0 gHz, 2 GIG RAM, ATI Mobility Radeon 9700 (128 MB)
Windows XP Pro SP2
http://beneaththelines.blogspot.com
