Valued Contributor
kgrover
Message 1 of 9 (1,318 Views)
LiDAR Classification
1318 Views, 8 Replies
08-17-2010 06:20 AM
I have several LAS files that I have brought into AutoCAD and created PCG point cloud files. You have the option to assign Civil3D properties so I assign the LAS classification properties but they don't apply to the file.
The classification style seems to work with the ISD file extension in Civil3D, but do the LAS classifications not work for the PCG format?? I can only view the PCG file by single color or by elevation range, not by classification.
Kevin
Distinguished Contributor
mnorton
Message 2 of 9 (1,304 Views)
Re: LiDAR Classification
08-17-2010 08:26 AM in reply to: kgrover
Try contacting Travis Reinke at scanable.org
Mike Norton - The Civil Guy
www.thecivilguy.com
Civil 3D 2014 (64)
Windows 7 Pro (64) SP1, 16 GB
AMD Radeon HD 6900
lisa_pohlmeyer
Message 3 of 9 (1,266 Views)
08-18-2010 02:27 PM in reply to: kgrover
If you'll go through the quick tutorial on Point Clouds, I think you'll find exactly what you're looking for.
Valued Contributor
kgrover
Message 4 of 9 (1,262 Views)
08-18-2010 02:57 PM in reply to: lisa_pohlmeyer
I have seen the tutorials but does not answer my question I posted.
I can view point clouds by classification if I bring the LAS file into a .isd point cloud file. I can assign a Civil3D style to the point cloud and can view by color, classification or elevation range.
I can't view point clouds by classification if I bring the LAS file into a .pcg file extension and add Civil3D properties to it. Everything only views as a single color or elevation range. It does not view classification.
Is this just a bug in Civil3D right now that the classifications don't come accross in the .pcg database??
LisaPohlmeyer
Message 5 of 9 (1,257 Views)
08-18-2010 04:30 PM in reply to: kgrover
ah, I misunderstood, sorry.
Lisa Pohlmeyer
C3D 2012 SP4, C3D 2015
Please use "Accept as Solution" if this solved your issue.
sharshbarger
Message 6 of 9 (704 Views)
05-23-2012 01:54 PM in reply to: kgrover
I'm having the same issue.  It works in 2012 just fine, but in 2013, it does NOT work.  When using Lidar data, unchecking all classifications except 2-ground, all point still show and they are gray in color.  I can't create a base ground surface with all points displayed.
I've opened a support request so we'll see what turns up out of that and I'll post my findings.
sharshbarger
Message 7 of 9 (685 Views)
05-24-2012 07:29 AM in reply to: sharshbarger
Update:
Straight from Autodesk Tech.
This issue you are reporting with the LiDAR Point Classification Style is a known issue with the 2013 product. I personally had logged this with Development a few weeks ago and it is currently under review with our Development Team.
Unfortunately there is not any known workaround for the time being, as attempting to import the same style from 2012 yields the same results. (BUT it works in 2012) I apologize for any inconvenience this may have caused.
As I mentioned on the phone I have logged this with Development for further review and I have linked this case to it. Per our policy we will now go ahead and close this case, leaving it linked to Development’s issue.
Very frustrated with Autodesk.  Why bring out an updated product each year and not fix the pre-existing issues?!?!?  Every update brings more issues to deal with.  Just my opinion.
Active Contributor
jeremy.2012
Message 8 of 9 (605 Views)
10-03-2012 06:58 AM in reply to: sharshbarger
Has anybody heard if Autodesk has offered any service pack or anything to fix this issue?
ceethreedee.com
Message 9 of 9 (513 Views)
12-17-2012 07:09 PM in reply to: jeremy.2012
Yep still wiating for FIX!???
Civil 3D 2014 (SP2)
Win 7 Pro x64 -DELL Precision Workstation T3500
Intel Xeon 3.3GHz (w3680) -24Gb Ram
NVIDIA Quadro 2000 (1GB)
ceethreedee.com
