To access MYSQL with FDO where should we place de file libmySQL.dll? With MAP its is in the <installation>\FDO\bin directory but how come there is no such directory with Civil?
extract from Map help "If you cannot connect to your MySQL data source, you may see an error message: "Specified credentials are not valid or the provider is unable to establish a connection." To resolve the issue, copy the libmySQL.dll file into the AutoCAD Map 3D\FDO\bin folder and try again."
...because we only have MAP Lite with Civil 3D...rather than the boxed standalone version so there are several little anomalies??
Here is where the FDO dll files are for a default Civil 3D 2013 installation:
C:\Program Files\Autodesk\AutoCAD Civil 3D 2013\bin\FDO
Give that folder a try.
