I’m having issues with surfaces, that are within xrefs, disappearing after saving & closing the drawing down then reopening. It seems most times I open the drawing, I have to input LEVELOFDETAILOFF again and regen. Sometimes the in contour labels are also missing or are the only things showing. Is this how the command is supposed to work or is there a more permanent solution? It gets annoying to find the disappearance after the set has been plotted to a PDF. I recently upgraded to 2015 from 2010, so this setting is new to me. Thanks.
Our xrefs are typically on a lock layer and for a test, I locked the labels as well. I changed level of detail off, saved, closed and got back in and the surfaces are not visible. A Regenall is done and still no surfaces or labels are visible until after I enter LEVELOFDETAILOFF again. Zooming in and out doesn’t change anything before that command is done. I thought it might be a video card issue, but other coworkers with different setups are having the same issue.
As a workaround I'd add (command "LEVELOFDETAILOFF") to your acaddoc.lsp.
Allen
Allen Jessup
CAD Manager - Designer
mine doesn't stay on the off setting either. it seems to change whenever i start printing.
