All,
Here is the setup, I received a survey base from another firm. All of there leaders of text are actually cogo points with labels. I have xrefed the file into my sheet file and rotated the view, so obviously nothing looks like I want. Typically I bring the text forward into my sheet and manipulate it here, but it is attached to a cogo point. I could copy the points and label styles into my current drawing, but this doesn't sound like the best practice. What is a good way to overcome this challenge?
Any talking points are appreciated
I got a pretty simple solution from Drew, with Eagle Point Pinnacle series. His solution was to use AD Center to import the layouts into the base, move the text where it looks good, then delete the layouts. It works and seems simple enough.
