Civil 3D Forum
Leader Text Placement Error
1 REPLY 1
russ0861
212 Views, 1 Reply
We are running AutoCAD 2012 with Carlson Survey 2013.
When I use the "special leader" command I am able to put the leader where I want it to be in the model space. I type in the text I want associated with the leader and hit the "enter" key, the text shows up no where near the drawing. It is miles away. The same thing is happening when I draw a 2D poly line using distance and bearing.
What is going on and how do I fix it?
Thank you
1 REPLY 1
tcorey
in reply to: russ0861
Perhaps your question should be asked on the Carlson forum. This forum is for Civil 3D questions.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Rail Community
