We are running AutoCAD 2012 with Carlson Survey 2013.
When I use the "special leader" command I am able to put the leader where I want it to be in the model space. I type in the text I want associated with the leader and hit the "enter" key, the text shows up no where near the drawing. It is miles away. The same thing is happening when I draw a 2D poly line using distance and bearing.
What is going on and how do I fix it?
Thank you
Perhaps your question should be asked on the Carlson forum. This forum is for Civil 3D questions.
