When I switch to a layout there is a panel "Layout Tools" that grabs focuse. I've never had it before, anyone know where/how I turn it off?
Solved by Jeff_M. Go to Solution.
>> switch to a layout there is a panel "Layout Tools" [...] how I turn it off
to be found >>>here<<<.
But make sure that functions like north-arrow, legend , map assign (command _MAPINSERTPLE) are not as easy to be reached then.
- alfred -
thanks but that isnt working. right-click doesnt give me an option to remove
You would need to remove this from your contextual ribbon tabs in the CUI editor.
John Mayo
One more note. If you haven't already you may want to copy the default cui for customizing. Each time you apply a service pack or run a repair of the install the layout tools will reappear.
John Mayo
