Civil 3D Forum
layout tabs missing
15 REPLIES 15
Message 1 of 16
rab8150
191524 Views, 15 Replies
layout tabs missing
My layout tabs are missing. How do you get them back?
15 REPLIES 15
Message 2 of 16
in reply to: rab8150
At the bottom of the Acad window, towards the right hand
side, will be the icons representing the Tabs. Right-click on one and the
option to show the tabs will be there.
My
Message 3 of 16
annw2
So are the icons.  This didn't work either to get the layout tabs back.
At least we can move to the layouts with the quick view.
Ann Wingert, P.E.
Message 4 of 16
mbennum
Did you maybe hit the Clean Screen button at the bottom right?
If that's not it, you can get the tabs back by going to Options > Display tab > Display Layout & Model Tabs checkbox.
Message 5 of 16
Jason.Hickey
You can get the layout tabs back from the drawing options window on the display tab. See the screencast found at http://screencast.com/t/zrv82GvCX5B for the exact location.
Jason Hickey
Premium Services Specialist
Autodesk, Inc.
Message 6 of 16
annw2
Which part of the screen cast is the "Drawing Options Window?"
We had already tried typing OPTIONS and the tab was already set for the layout tabs, but they still won't display.
Ann Wingert, P.E.
Message 7 of 16
mbennum
in reply to: annw2
Is the drawing maximized inside the Autocad window?
 If it isn't, the tabs could be off the bottom of the screen.  Thats the only other thing I can think of that would hide them.
Message 8 of 16
annw2
We closed the file down during lunch, shut down AutoCAD and restarted after lunch.
That tabs came back. (?)
Ann Wingert, P.E.
Message 9 of 16
whattheheesy
1) right click
2) at the very bottom, select "Options"
3) "Display" tab
3) at the bottom under "Layout elements"
4) check "Display Layout and Model tabs"
Message 10 of 16
Hidden_Brain
you can also type:
(setenv "ShowTabs" "1")
at the command line to bring them back.
Message 11 of 16
Veronica50506
I know this was long ago, but just in case someone else references this discussion:
1) tabs may be turned off in "options"
2) clean screen may be on
3) you may be in block editor
Message 12 of 16
KDSII
in reply to: mbennum
I had this problem, and the issue was the screen maximization. Just click on the icon right next to the "Close" icon (X) and the tabs will show up. They are there, but you just can't see them because your window is either minimized or maximize.Not sure which, but doing this fixed mine!
Message 13 of 16
EarlChornsbay
In the command line,
type in "LAYOUTTAB"  This system variable is set to 0 by default.
Switch it to "1"
This will bring the normal tabs back to the bottom left of the screen.
Message 14 of 16
in reply to: annw2
There is a possibility of cascading the layouts also. Please try clicking the cascade on the screen for all the tabs will appear.
Message 15 of 16
thank you bro.
Message 16 of 16
oscarUS7JK
in reply to: EarlChornsbay
didn't work for me, I'm using AutoCAD MEP 2020. LAYOUTTAB was already set to 1.
Rail Community
