0 Kudos
Post 1 of 4
Layout & template
305 Views, 3 Replies
10-06-2011 12:25 PM
hello,
i've problem, i had moudified the template of plan and profile  and i had added a new layout inside this one
but when i try to create viewframe using the viewframe wizard under the sheets tab i dont find the last layout wich i had created
and here when  i try to use the same modified template to create viewframe from sheets tab of the viewframe wizard
Go back to the template and look at the viewports you have for that layout. If you don't have one defined as "Plan" and one as "Profile" it won't show up on the list.
41 Kudos
Post 2 of 4
Re: Layout & template
10-06-2011 08:20 PM in reply to: fayforum
Bruce Klug
AutoCAD Expert Elite
AutoCAD Civil 3D 2014 Certified Professional
Infrastructure Design Suite 2014 (SP2)
Testing Civil 3D 2015
Win 7 Pro, 64-bit
0 Kudos
Post 3 of 4
10-06-2011 11:59 PM in reply to: klugb
Thank you very much Bruce, it works now
41 Kudos
Post 4 of 4
10-07-2011 07:51 AM in reply to: fayforum
No problem,
Now if ADSK would give us the Plan/Plan option in the view frame/Create sheets creation I would be happy.
I know there are workarounds but a standard option for it would be good.
Bruce Klug
Win 7 Pro, 64-bit
