Civil 3D Forum
Layout & template
3 REPLIES 3
fayforum
504 Views, 3 Replies
Layout & template
hello,
i've problem, i had moudified the template of plan and profile  and i had added a new layout inside this one
but when i try to create viewframe using the viewframe wizard under the sheets tab i dont find the last layout wich i had created
and here when  i try to use the same modified template to create viewframe from sheets tab of the viewframe wizard
3 REPLIES 3
klugb
in reply to: fayforum
Go back to the template and look at the viewports you have for that layout. If you don't have one defined as "Plan" and one as "Profile" it won't show up on the list.
Bruce Klug, P.E.
AutoCAD Expert Elite Alumni
AutoCAD Civil 3D Certified Professional
Civil 3D 2023.2.1
Win 10 Enterprise, 64-bit
fayforum
in reply to: klugb
Thank you very much Bruce, it works now
Tags (1)
klugb
No problem,
Now if ADSK would give us the Plan/Plan option in the view frame/Create sheets creation I would be happy.
I know there are workarounds but a standard option for it would be good.
Bruce Klug, P.E.
Civil 3D 2023.2.1
Rail Community
