Civil 3D Forum
Layer Translator or laytrans
5 REPLIES 5
520 Views, 5 Replies
We are trying to devised a way to quickly control layers and linetypes due to the vast differences depending on the tech creatign the drawing... I set up a DWS file that has the layers and linetypes define; to that  end, using laytrans works fine but all converted linetypes are 10 times the size... I have messed with LTscale, drawing settings, units, celtscale, nothing works... Ideas?
Chris
5 REPLIES 5
Sinc
More details...?
Starting with C3D 2008, the best setting is to have LTSCALE=1, PSLTSCALE=1, and MSLTSCALE=1.  That seems to make everything work just fine.
Sinc
Sinc
in reply to: Sinc
Oh, and I'm not sure, but some of these settings might be viewport-dependent, so it's best to make sure they are all set correctly in the first place.  Then new viewports automatically use the settings from modelspace (I think... may be wrong).
We have them all set the way we want them in our DWT, and have no issues along these lines.
Sinc
Sinc
Oh, another idea is that you may be accidentally overiding your linetype scales via your Properties...  You can set a linetype scale in your Properties window when you have nothing selected, and then everything you create from then on out will have a custom linetype scale.  Easiest way to check for this is to select nothing, then go to the Properties window, and check that Linetype scale is set to 1.00 (or 0.50, if you prefer that method, as opposed to redefining your default acad.lin or AeccLand.lin files).
(Disclaimer:  remember that if you redefine the .lin files, you have to reload them.  The linetype definitions are actually stored in your drawing, so you have to reload them if you edit the .lin files.)
Sinc
in reply to: Sinc
Sorry I forgot to add the basic info... I am using Civil 3d 2012. The linetypes are custom due to the affliation with the FDOT standards. Also, I confirmed in each drawing that the lt, mslt, and psltscale are all set to one. Also I should note, the translator worked properly when used on a file that we use a s template which has our line types. I am trying to concert a survey file that is using the basic ACAD linetypes which I think is the problem but I wasn't able to purge all the linetypes out. I also don;t quite know why this would matter since we are not using any default ACAD linetypes we are translating to new ones that we created.
BUMP
Rail Community
