I have a drawing in paperspace with two separate viewports, an overall view and a detail below it at a different scale. There are layers that must show in paperspace ONLY in one viewport, and layers that must show in paperspace ONLY in the other viewport.
Naturally, this means that all layers intended to show in BOTH viewports must be ON in paperspace, but that SOME layers must be frozen in the UPPER viewport but visible in the LOWER, and conversely that those layers shown in the LOWER (detail) viewport must be frozen in the UPPER viewport, in order to avoid doubling up.
This was very easy in LDD; in model space all the layers to be shown were left on, and in paperspace the viewport freezes were used to sort those that were to appear or be invisible in each of the two viewports in the drawing.
However, once these parameters are set up in model space and paperspace as required, and the drawing looks the way it should, I create the 0 PLOT layer state and click SAVE as shown in the appended JPG, and BOOM!: "Current layer state: *UNSAVED*," as shown in the appended JPG. This persists whether or not either or both of the "restore options" checkboxes is checked or unchecked, and believe me, we've tried all the combinations.
Has Autodesk in its wisdom somehow made this simple task more complicated than it was in LDD? Thanks for any assistance.
Solved by Jay_B. Go to Solution.
M,
I'm curious. If LDT does everything faster and easier, why are you working in Civil 3D?
Dave
Dave Stoll
Las Vegas, Nevada
M,
Your question got me to thinking about layers and plotting. I don't plot much, so I didn't realize how many new commands there are in the Layer Properties Manager. Now I'm reading through the Help Section and discovering a world of cool new functionality. Thank you.
Dave
Dave Stoll
Las Vegas, Nevada
I dou bt that LDD vs Civi 3D has anything to do with it. Possibly 2009 vs your version. Remember. If you restore a layout layerstate in modelspace you will get unexpected results and the Current layerstate will say unsaved. Don't know if this applies to your situation.
Allen
from my nook tablet
Allen Jessup
CAD Manager - Designer
I'm running Civil 3D 2014, but have arrived straight from LDD, hence the comparison. In LDD, one set one's layer state, and in paperspace one used the viewport freeze option to control what was seen in multiple viewports. Switching between paperspace and model had no effect on layer state stability and produced no unexpected results. I remain mystified. There must be some setting that permits the elimination of unexpected results.
Thanks for the response, though.
As far as I can tell the *UNSAVED* doesn't seem to mean a whole lot in regards to selecting SAVE in the Layer State Manager.
When saving a Layer State for the scenario you've described as using the pick freeze / VP FREEZE option within a Viewport they seem to work as expected.Attached is a dwg which has text on 2 separate layers, Layer 1 & Layer 2 and contains 2 Viewports. 3 Layer States were created form within MSof the Viewports. See attached dwg and click in MS of VP and choose any of the 3 available Layer States and Select "Restore".Are you creating the Layer States from within MS of the viewports and are you choosing "Restore" to set the desired Layer State in a given VP?BTW - Clicking on that arrow @ lower right of the Layer States Manager will expand the dialog. dwg was created in 2014.
Yes. I just had one of those DUH moments. "Unsaved" refers to the current Layer State in the drawing not in the dialog box. It only changes after you restore a Layer State. Even if the layers in the drawing match one of the Layer States it doesn't change the "Current Layer State" until you restore one. Doesn't matter if it's identical to the layer state in the drawing.
That's an old dialog box and it was probably programed to only reference itself.
Allen
Allen Jessup
