Several weeks ago I install the Hot Fix for the Layers Property Crash issue. I haven't had any problems until now. The problem has started all over again. I redownloaded the fix and copied the AcLayer.dll file into the correct folder. I have restarted my computer and it hasn't helped. What patches or fixes am I missing? Please help, I'm stuck!
Hi jreed,
Did you tried to Repair the AutoCAD Civil 3D 2012 SP 1 install?
Repair Installation
Go to Control Panel > Programs & Features > click on AutoCAD Civil 3D 2012 > Uninstall/Change.
In the AutoCAD Civil 3D 2012 dialog box, click Reinstall or Repair.
After the process, restart the computer and check the product behavior.
Please, keep in mind these aditional information:
1) Before applying this update, make sure that any customizations made to the user profile (such as, customizations made to the support file search paths, print file customizations, printer support file paths, redirections, custom template settings, and so on) are exported to a secure location, then imported and reapplied after the update has been successfully installed.
2) You cannot run an automatic uninstall to remove this update. To restore your version of AutoCAD Civil 3D 2012 to its pre-update state, uninstall AutoCAD Civil 3D 2012 and reinstall it.
If this procedure do not solve your problem, you can also try the solution in the link below:
http://usa.autodesk.com/getdoc/id=TS16436702
Please, try these suggestion and let me know if it solves your problem.
