Civil 3D Forum
layer problems
9 REPLIES 9
Message 1 of 10
capt.crayola
725 Views, 9 Replies
layer problems
So here's a little weirdness I've been experiencing with AutoCAD Civil 3D 2013 recently.... I copied some simple linework over from my current drawing to a file I've got XRef'd into my current drawing. The layer copied over fine, color etc. However, I can't seem to get it do display - the XRef layer is turned on, not frozen and the XRef itself is on it's own layer and is displaying fine, but the copied layer isn't....Any suggestions??
As a footnote, I've also been having difficulty with my layer properties manager. I'll isolate a layer in the properties manager, but the layer doesn't isolate - when I look at the layers using the pulldown in the ribbon, all of the layers are still on.....?!?!
Footnote #2 -Please forego any comments regarding the 'newbie' factor - I've got 17 year experience, and teach AutoCAD myself....
Sean
Dell Precision M6700 laptop
Intel Core i7-3740QM quad core 2.7Ghz with 16 GB Ram
NVidia K400M 2GB video, Windows 10 Professional 64 Bit
9 REPLIES 9
Message 2 of 10
Jay_B
in reply to: capt.crayola
Is it possible that the Layer Settings in Layer Manager are set to "Lock and Fade" and not "Off" ?
In this case the layers are locked when isolated instead of turned off (which is also the default setting).
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Message 3 of 10
rkmcswain
1. If you pasted (or inserted) the linework as a block, the block itself resides on a layer that could be frozen in your parent drawing.
2. Does it act any differently if you use the LAYISO command instead?
R.K. McSwain     | CADpanacea | on twitter
Message 4 of 10
capt.crayola
in reply to: Jay_B
No, if that were the case, the layers would fade, but there's no visible change - even after a regenall
Sean
Message 5 of 10
capt.crayola
in reply to: rkmcswain
1. The linework was inserted as simple linework - there's a block with it, but none of the lines show up in my current drawing.
2. Yes, I can still isolate the layers using LAYISO, which I regularly do anyway... the layer issue only shows up in the Layer property manager - I don't know if the situations are related, but it's the only other related issue I'm having....
Sean
Message 6 of 10
LeafRiders
If you set your LAYERDLGMODE to "0" and proceed to use the old school layer manager does this fix the problem?
Message 7 of 10
Pointdump
CC,
"Please forego any comments regarding the 'newbie' factor - I've got 17 year experience, and teach AutoCAD myself...."
Sniff! You're asking for help, but will be offended if anyone suggests something beneath your station? Well, I consider myself to be a permanent student, even though I've got as many years "experience" as you. So let me offend you:
1. First, tell everyone what version of AutoCAD you're using, what service pac, what operating system. And describing a problem is a good start, but sometimes you need to add a Screengrab or even post the drawing.
2. Because of the breadth of experience and use by members here, you're going to get a selection of ideas from easy to complex. That's the great thing about this Forum.
3. Consider all ideas, politely and graciously. I can't tell you how many times I've fixed a problem by a Regen or "turning it off, then turning it on again."
Now, to your problem:
"I copied some simple linework over from my current drawing to a file I've got XRef'd into my current drawing."
That sounds like a possible circular reference. I haven't done much with XRef's, but could it be that you just need to save both the XRef and your drawing, and then re-open your drawing?
Do you have any unreconciled layers? I just learned last week that there was such a thing as unreconciled layers, and I don't know what problems they can cause, but now I look for the Yellow Exclamation Thingy in the lower right Status Bar.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
Message 8 of 10
capt.crayola
in reply to: LeafRiders
good thought I never considered this- unfortunately no change...
Sean
Message 9 of 10
capt.crayola
in reply to: Pointdump
@Pointdump wrote:
CC,
Dave
1. You sir, read FAR too much into my post.... I was just trying to forgo endless comments like 'did you turn the layer on.....'
2. I was careless to not put any Particulars, my apologies - I'm using Civil 3D 2013 SP2 on a Dell Precision M6700 laptop with Intel Core i7-3740QM quad core 2.7Ghz with 16 GB Ram, NVidia K400M 2GB video, Windows 7 Professional 64 Bit
3. I do receive all solutions politely and graciously, and any assistance from other experts is GREATLY appreciated. Further, as a teacher I do learn as much from my students than they do from me, however in troubleshooting AutoCAD behaviour that I deem odd and have attempted the 'obvious' and unorthodox to solve the problem, I may have been more abrupt than intended - again my apologies.
thank you for your reply - and unfortunately the circular reference isn't valid in this case - although the drawings are circular, having attached them as 'overlay' into each other would forgo this problem generally, but we're talking about simple autocad objects - lines, circles etc. Your comment about unreconciled layers is a good one, but alas already tried.
Sean
Message 10 of 10
capt.crayola
thank you Gentlemen - your suggestions of an 'old school' approach made me get 'back to basics' as it were.
When all else fails with XRef's - DETACH and RE-ATTACH said XRef..... it seems to have cleared up the problem (for now at least)
Sean
Sean
Rail Community
