Civil 3D Forum
Layer problem
4 REPLIES 4
forrest16
350 Views, 4 Replies
Layer problem
In model space if i go to layers manager and turn off a layer why does it still show up in model space.  Civil 3d 2013
4 REPLIES 4
in reply to: forrest16
If you do a  REGEN, does the layer become visable? If so, check your REGENAUTO setting, it may be turned off.
forrest16
my regen auto is on.  but my problem is when i turn a layer off it still shows in model space.  if i freeze the layer then it turns off but if i simply turn the layer off it is still visible.
troma
There is a setting for layers that are off to either not display, or lock and fade.  Is it doing the lock and fade for you?
Mark Green
Working on Civil 3D in Canada
Joe-Bouza
If the components of the object are on different layers turning off the insert layer would not turn off the component layer.
Example:
default layer for point insert = V-node
marker style layer  = c-topo-spot
label style layer = V-node-text
turn "off" v-node and the point and label style remain. freeze v-node they all go.
Think of c3d ojects as nested blocks made of components on thier own layers and it has a singular insert point
Your Name
Your Name
Rail Community
