I created a layer. The same is not seen in the list of layers, but is recognised in the quick select filter. How can make the layer seen in the quick select filter current in the drawing.
Thanks.
Solved by tcorey. Go to Solution.
In the layer dialog, left hand side, you have selected to only display used layers. If this layer is new and has no objects, it won't display. Pick All Layers and you will see it.
