Somepin wrote:
> Canned response yay..... Maybe i should update my sound card drivers
> too huh?
Somepin,
Autodesk had investigated the issue reported by several users, found the
cause, and posted a resolution. Did that resolution not work for you?
> Now for something actually relevant: gdi objects work the same across
> the entire windows platform Theres no reason a listview in windows
> (using same system font as autocad's windows) would display correctly
> 100% of the time and a similar listview in autocad (using same system
> font) would display correctly only ~70% of the time unless you added
> some extra fun into the paint method.... like my disappearing text
> "feature".....
As you may have noticed from the KB article, this is a cache corruption
issue and you may have observed that simply logging in as a different
user might not have triggered the problem, even though you would have
been running Civil3D on the same system. This is why these kinds of
issues are called "bugs" 🙂
> Aparently, my video card drivers were fixed in Civil3D 2006 SP2,
> because i no longer see this issue
It's hard to say what fixed the issue in your case. Did you not change
_anything_ else on your system between the time that you saw the issue
(12/1/2005) and your response here (2/10/2006)?
Any case, it's great you are not seeing the problem any more. Good luck.
Himanshu Gohel. Civil 3D Team, Autodesk, Inc.
Autodesk Civil 3D Product Information: http://www.autodesk.com/civil3d
