Is there a way to set up a layer filter to strip off the xref name?
I have standard layers in all my drawings. I want to use a filter to setup the type of drawing.. i.e erosion control.
However, from project to project the xref file name changes so filters don't work with the new name...
or maybe I just don't know how to use them right?
Anyway, if there is a way to hide the xref filename from the prefix of the layer.. if so, a standard layer filter would grab all the layers with the same name.
Civil 3D 2012 SP2
Win 7, 64 bit
You can change the name of the xrefs in the xref pallette. This would get you to a standard name for all layers.
That's not exactly what I was looking for but it's a pretty good work around. Thanks.
You can set up the layer filters with wildcards. Have to be careful with layers that have the same ending. (ie, *Storm will filter ex storm, and proposed storm layer names)
