Civil 3D Forum
Layer filters stop working
3 REPLIES 3
jak79
329 Views, 3 Replies
I am using 2013 C3D with SP1. After I publish sheets using the sheet set manager my layer filters stop working (will not filter layers, it will just display the last layer filter used prior to running the sheet set manager). Any help on this is appreciated.
3 REPLIES 3
tcorey
in reply to: jak79
Do Layer Filters work if you set LAYERDLGMODE to 0?
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
jak79
in reply to: tcorey
That appears to work if I change the setting on "Layerdlgmode" to 0. Problem now is that's not the way I want to run my layer properties manager window. I prefer to have it docked and using auto-hide.
Thanks for the reply.
rkmcswain
in reply to: jak79
Rail Community
