Civil 3D Forum
Layer Filter Problem
4 REPLIES 4
neilyj666
1531 Views, 4 Replies
I want to create a Layer Filter that excludes both Civil Layers and Xrefs
I have created one that excludes Civil objects Smiley Happy (Excl Civil.jpg)  but when I add a filter for excluding xrefs as well the Civil objects appear in the filter again  - indeed all the layers are included again (Excl Xref.jpg); if I invert the filter nothing is dsplayed.
Anyone able to come up with the correct fllter for this??
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2025 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
4 REPLIES 4
in reply to: neilyj666
Not sure how to create a single filter. If you stack the filters by filtering the xrefs first then create a sub filter for the civil layers inside the xref filter, that works.
Hey thats a meme, ..."yo dawg, I heard you like filters, so I create afilter in your filter so you can filter your filter"
neilyj666
That stacking trick works - thanks
The Layer filter include layers from the filter in the first line being layers not starting with C- (which includes the xref layers) AND the layers from the filter in the second line being layers not including | (which includes the Civil layers) so in effect, you will only exclude xrefed civil layers.
There are two ways I can think of that you can achieve what you want.
  1. Set up a filter that includes the civil layer and the xref layers and then invert the filter. Basically what you have, but remove the tildes and then invert.
  2. Set up an exclusion filter for the civil layers and then create a sub filter of it to exclude the xref layers. This will filter the xref layers out of the layers which have already been filter of civil layers.
If a post provides a fix for your issue, click on "Accept as Solution" to help other users find solutions to problems they might have that are similar to yours.
Andrew Puller
Maitland, NSW, Australia
Windows 10 Enterprise 64bit
Intel core i7 11800 @ 2.30 GHz with 32GB Ram
Civil 3d 2023
thanks for the explanation - I wondered if the filter was doing something as you described
Rail Community
