I want to create a Layer Filter that excludes both Civil Layers and Xrefs
I have created one that excludes Civil objects (Excl Civil.jpg) but when I add a filter for excluding xrefs as well the Civil objects appear in the filter again - indeed all the layers are included again (Excl Xref.jpg); if I invert the filter nothing is dsplayed.
Anyone able to come up with the correct fllter for this??
neilyj (No connection with Autodesk other than using the products in the real world)
Not sure how to create a single filter. If you stack the filters by filtering the xrefs first then create a sub filter for the civil layers inside the xref filter, that works.
Hey thats a meme, ..."yo dawg, I heard you like filters, so I create afilter in your filter so you can filter your filter"
That stacking trick works - thanks
The Layer filter include layers from the filter in the first line being layers not starting with C- (which includes the xref layers) AND the layers from the filter in the second line being layers not including | (which includes the Civil layers) so in effect, you will only exclude xrefed civil layers.
There are two ways I can think of that you can achieve what you want.
thanks for the explanation - I wondered if the filter was doing something as you described
