I have just updated from 2011 to 2015. Can someone tell me how to find the layer dialog box? Its not in the ribbon section for layers. You cant type on the command line and get it. And of course again the Autodesk HELP is absolutely no help at all.
Solved by Jeff_M. Go to Solution.
if I type classic layer dialog box comes up if i type layer nothing comes up just a little flicker of the screen when i click the menu button (perferred way) nothing happens just the flicker of screen, i surly don't want to type classic layer a hundred times a day, what happened to the '_layer dialog box ??????????????????????????????????????????
Mark Green
Working on Civil 3D in Canada
