Civil 3D Forum
LaneSuperelevationAOR subassembly hatch
1 REPLY 1
civman_daar
286 Views, 1 Reply
I have my sub-base subassemblies in my road section using a gravel hatch pattern.  For the sub-base under the curb it displays correctly.  For the LaneSuperelevationAOR subassembly, it does not display.  The shape style which I use for the sub-base for the curb and the LaneSuperelevationAOR subassembly are identical.   As a test,  I switch the shape style to NO_DISPLAY, and the sub-base is turned off on the subassemblies,  which is correct.  Why would one display and not the other?
1 REPLY 1
civman_daar
in reply to: civman_daar
I figured out a workaround.  The problem appears to be when the base height is set to zero, the sub-base hatch will not appear.  I changed the base height to 0.0000000000000001 and the sub-base hatch appeared.  This must be a bug in the software.  The zero height assignment for pavement 2 does not affect the hatching for pavement 1.
Rail Community
